This guide shows step by step instructions for replacement of the thermostat assembly in the Holmes HEH8031 heater.
Ensure the device is unplugged from the wall outlet.
Remove eight 12-mm Phillips #2 screws from the back cover.
Turn heater over so the controls are facing up.
Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
Remove four 12mm Phillips #2 screws from the circuit board.
Remove two Phillips #2 12mm screws from housing
Separate fan assembly from heating coil
Remove 1 Phillips #2 screw
remove solder from thermostat wire on circuit board
