This guide will demonstrate how to remove and replace the safety weight in the Holmes HEH8031 Heater.
Ensure the device is unplugged from the wall outlet.
Remove eight 12-mm Phillips #2 screws from the back cover.
Turn heater over so the controls are facing up.
Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
Remove four 12mm Phillips #2 screws from the circuit board.
Remove wires from safety weight, as shown.
Pull upward on the blue connectors.
Unscrew the Phillips #2 10 mm screw from the safety weight on the rear housing panel.
