The Holmes Blizzard Electric table fan comes pre-assembled, but external forces could cause the adjustment knob on the base to break or snap. Luckily there is a way to replace the knob and clean the fan blades from collected lint or dust. You will need a Phillips head screwdriver and some pliers as the screws could be tricky to pull out. Once the fan blades are wiped down and the knob is replaced, the fan will correctly stabilize and there will be no debris flying out when the fan spins.
            Unscrew the three black screws on the back of the fan head and place the screws aside.
            Remove the fan grille and clean any dust from the blades.
            Unscrew the side of the fan above the knob and below the grille, then remove them.
            Remove the old knob and place the new adjustment knob into the base, then secure it in place.
            Reattach the grille and secure the open parts of the fan.
            Ensure the new knob is tight.
            Tighten the old and new screws back into place.
The cleaning procedure and knob replacement should help this fan operate with more stability while keeping things breezy. If it becomes difficult to remove screws or place them back, I recommend a pair of pliers just in case you run into any issues.
