Holley 4 Barrel Carburetor Gasket Replacement
  1. Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure your carburetor has no fuel inside.
  2. Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 47 mm flat head screws.
  3. Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bowl from the side of the carburetor.
  4. Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 63 mm flat head screws.
  5. Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bowl and the steel fuel line from the side of the carburetor.
  6. Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spacer from the side of the carburetor.
    • If you need to, use a flat head screwdriver and carefully pry the spacer off of the carburetor.
  7. Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 2.5 mm hex screws from the secondary metering block.
    • If you need to, use the small flat head screwdriver that will fit the head of the hex screws in order to remove the screws.
  8. Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a flat head screwdriver, remove the thin gasket from the side of the carburetor.
  9. Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Holley 4 Barrel Carburetor Gasket Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 20 mm Phillips screws from the bottom plate of the carburetor.
    • Then, carefully remove the gasket from the bottom plate. Use a flat head screwdriver, if needed, to pry the gasket off of the plate.
crwdns2935229:05crwdne2935229:0
Chad Giesmann
crwdns2935283:006/01/16crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
Central Coast New Tech High, Team 7-2, Rushing Spring 2016 crwdns2935289:0Central Coast New Tech High, Team 7-2, Rushing Spring 2016crwdne2935289:0
CCNTH-RUSHING-S16S7G2
crwdns2942667:0crwdne2942667:0 4,750
