crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Hitron CODAcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Hitron CODA Teardown, Remove case screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove rubber covers first. Attached with some weak glue, they are relatively easy to pry away. Only the 2 at the back of the device have screws underneath.
    • Use a screwdriver to remove the screws.
  2. Hitron CODA Teardown, Pry open case tabs: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitron CODA Teardown, Pry open case tabs: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Plastic tabs line the case where the upper and lower halves meet.
    • I found it easiest to start prying from the sides of the back.
    • Keep prying until the case is fully separated and the top half lifts up/forwards.
  3. Hitron CODA Teardown, Component identification (top of PCB): crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitron CODA Teardown, Component identification (top of PCB): crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  4. Hitron CODA Teardown, Remove SoC heatsink: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Remove SoC heatsink: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Remove SoC heatsink: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful, yanking too hard can damage/disconnect the processor.
    • Squeeze the tip of the heatsink legs (e.g. with pliers) so you can pull them back through the PCB holes.
  5. Hitron CODA Teardown, Remove RF shield: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitron CODA Teardown, Remove RF shield: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up the tabs around the edge of the shield.
  6. Hitron CODA Teardown, Component identification (top, under heatsink/shield): crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitron CODA Teardown, Component identification (top, under heatsink/shield): crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  7. Hitron CODA Teardown, Remove PCB from case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the PCB away from the case.
  8. Hitron CODA Teardown, Component identification (bottom of PCB): crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Serial NAND EEPROM (1Gb): Kioxia TC58NVG0S3HTA00 datasheet
    • Debug headers factory firmware bootlog
    • Once you plug in your modem to the cable network, your ISP will update the firmware to a version that has features for, and is tested to be compatible with, their network (it's part of the DOCSIS spec, specifically the "SwUpgradeFilename" option in the config file. See here for details).
    • My modem, once it upgraded to the Xfinity firmware, no longer shares its bootlog to UART on either debug header (as verified with a logic analyzer, both attached and unattached to the cable network).
    • There is a silkscreen arrow pointing to one pin on each of the debug headers. The pin on the opposite end, farthest away from the arrow, is ground.
  9. Hitron CODA Teardown, Remaining components to be identified: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitron CODA Teardown, Remaining components to be identified: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Product number 383300420402-11
    • Unpopulated connector H084E0581B
    • Various test points (labeled "TPXXX")
    • 602 910
    • V39 3601 2049
    • U710
  10. Hitron CODA Teardown, Further closeups: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
  11. Hitron CODA Teardown, Further closeups: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  12. Hitron CODA Teardown, Further closeups: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  13. Hitron CODA Teardown, Further closeups: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  14. Hitron CODA Teardown, Further closeups: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  15. Hitron CODA Teardown, Further closeups: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitron CODA Teardown, Further closeups: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
Kyle Westhaus
crwdns2935283:005/15/20crwdne2935283:0
786 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 114
crwdns2942667:0crwdne2942667:0 1,751
