Hitachi CP-X440 Power Supply Unit Replacement
  1. Hitachi CP-X440 Power Supply Unit Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the projector upside down so the bottom is facing up.
    • Using a Phillips #1 screwdriver remove the six black 2 mm screws.
    • The screws are deep in the holes, so be careful when removing them as they can easily fall off the screwdriver tip.
  2. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the projector right-side up and navigate to the back panel.
    • Remove the three black 10 mm screws on the back panel with a Phillips #1 screwdriver.
    • Remove the two silver 10 mm screws on the power switch panel with a Phillips #1 screwdriver.
  3. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now turn the projector so the front is facing you.
    • Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
  4. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the cables from their white connectors on the circuit board.
  5. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull out the three orange ribbons from their white connectors on the circuit board.
    • You can use a spudger tool to pry them out of place.
  6. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five silver 5 mm screws on the circuit board with a Phillips #2 screwdriver.
  7. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard so the projector is exposed.
  8. Hitachi CP-X440 Power Supply Unit Replacement, Power Supply Unit: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement, Power Supply Unit: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the silver plastic protective piece from the top of the power supply unit.
    • Remove the black pin holder by using the spudger.
  9. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 10 mm screws that are holding the power supply unit to the projector.
  10. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wires that are attached to the projector from the power supply unit.
  11. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black wire by using the Phillips #2 screwdriver to remove the 10 mm screw.
    • Pull on the metal bracket which should come free, and then pull the wire up so it is released.
  12. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black wire by using the Phillips #2 screwdriver to remove the 10 mm silver screw.
    • Pull on the metal bracket which should come free. Then pull the wire up so it is released.
    • The third picture marks where the base of the second picture's screw is located.
  13. Hitachi CP-X440 Power Supply Unit Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the last 10 mm screw to the secondary motherboard using the Phillips #2 screwdriver and the power supply unit will lift free.
noah wright
crwdns2935283:003/21/22crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 2-2, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 2-2, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S2G2
crwdns2942667:0crwdne2942667:0 265
