Hitachi CP-X440 Lens Replacement
    1. Hitachi CP-X440 Lens Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the projector upside down so the bottom is facing up.
      • Using a Phillips #1 screwdriver remove the six black 2 mm screws.
      • The screws are deep in the holes, so be careful when removing them as they can easily fall off the screwdriver tip.
    2. Hitachi CP-X440 Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the projector right-side up and navigate to the back panel.
      • Remove the three black 10 mm screws on the back panel with a Phillips #1 screwdriver.
      • Remove the two silver 10 mm screws on the power switch panel with a Phillips #1 screwdriver.
    3. Hitachi CP-X440 Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Now turn the projector so the front is facing you.
      • Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
    4. Hitachi CP-X440 Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently remove the cables from their white connectors on the circuit board.
    5. Hitachi CP-X440 Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull out the three orange ribbons from their white connectors on the circuit board.
      • You can use a spudger tool to pry them out of place.
    6. Hitachi CP-X440 Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five silver 5 mm screws on the circuit board with a Phillips #2 screwdriver.
    7. Hitachi CP-X440 Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the motherboard so the projector is exposed.
    1. Hitachi CP-X440 Lens Replacement, Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Lens Replacement, Lens: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Lens Replacement, Lens: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • As you look at the the device overhead, you will see three pieces of orange ribbon.
      • Attached to the orange ribbon will be a stabilizer over the lamp.
      • On each side, unscrew the two 1 cm screws with a Phillips #0 Screwdriver.
      • Then remove the piece holding the orange ribbons, called the stabilizer from this point on.
    2. Hitachi CP-X440 Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Lens Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once the stabilizer is removed, set it to the side.
      • Use a Phillips #0 screwdriver to remove the two 1 cm screws on both sides of the lens.
      • The lens element should be easily lifted out of the device.
    3. Hitachi CP-X440 Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the lens element is safely removed, you will see 4 tiny 1/2 centimeter screws surrounding the lens.
      • Use a Phillips #000 screwdriver to unscrew each screw. This will allow you to easily remove the lens.
    4. Hitachi CP-X440 Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Lens Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X440 Lens Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once the lens is safely removed, turn it face up.
    5. Hitachi CP-X440 Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X440 Lens Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Begin to gently unscrew the lens by hand, being mindful of light pressure.
      • After a few turns, the lens should be easily removed.
Harper Hollon
crwdns2935283:003/21/22crwdne2935283:0
238 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 2-2, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 2-2, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S2G2
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 456
