In this guide, users will learn how to replace the lamp in the Hitachi CP-X440 Projector. If the Projector is not displaying an image when turned on, the lamp may need replacing.
Flip the projector upside down so the bottom end is showing and press down the two tabs on the bottom left of the projector
Lift the lamp cover up and set to the side
Use a Flathead #4 screwdriver to remove the two 1.0 cm silver screws from the back of the lamp piece.
Gently pull the lamp piece out of the projector.
