The speakers provide sound for the projector. If the sound is muffled or distorted, the speakers might be at fault. If you've determined that the speakers of your Hitachi CP-X2010N projector have failed, follow this guide to replace them.
Before handling the speakers, ensure the device is powered off and unplugged. Also make sure that the projector has cooled off if it has recently been used, as it could become warm after prolonged use.
Flip the projector upside down to expose the screws on the underside.
Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
Flip projector right side up and orient it so you are facing the rear panel.
Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
Remove the panel from the body of the projector.
Pinch the edges of the two connectors and carefully disconnect both wires from the motherboard.
Lightly grab the speakers and pull them up and towards yourself to remove the speakers from the case.
