Hitachi CP-X2010N Lens Replacement
    1. Hitachi CP-X2010N Lens Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement, Top Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement, Top Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the projector upside down to expose the screws on the underside.
    2. Hitachi CP-X2010N Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
    3. Hitachi CP-X2010N Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip projector right side up and orient it so you are facing the rear panel.
    4. Hitachi CP-X2010N Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
      • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
    5. Hitachi CP-X2010N Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
      • Remove the panel from the body of the projector.
    1. Hitachi CP-X2010N Lens Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully pinch the edges of the two blue connectors and pull upwards to remove them from the motherboard.
      • Carefully pinch and remove the small gray connector next to the blue wire opposite the speakers.
    2. Hitachi CP-X2010N Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #2 screwdriver to remove the two black 14 mm screws securing the button array.
      • Move the wires for better access to the screws if needed.
    3. Hitachi CP-X2010N Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the bracket that was being held by the screw.
      • Take a picture or memorize its orientation for easier reinstallation.
    4. Hitachi CP-X2010N Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the button array and network adapter out carefully.
      • Make sure all the wires connected to the array are unplugged.
    5. Hitachi CP-X2010N Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #2 screwdriver to remove the silver 10 mm screw securing the ground wire.
      • Keep the screw and washer in an easily accessible place.
    6. Hitachi CP-X2010N Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #2 screwdriver to remove the black 14 mm screw securing the motherboard to the case.
    7. Hitachi CP-X2010N Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Delicately pinch and pull off all the wired connections surrounding the outside of the motherboard.
    8. Hitachi CP-X2010N Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three orange cable locks. Then, you can safely pull the cables out.
      • Too much force could break the ribbon cable.
    9. Hitachi CP-X2010N Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the motherboard out from the projector carefully so that it doesn't catch on any other components.
    1. Hitachi CP-X2010N Lens Replacement, Lens: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement, Lens: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement, Lens: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #2 screwdriver to remove the three black 14 mm screws holding down the projector housing.
    2. Hitachi CP-X2010N Lens Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Loosen the three silver Phillips #2 screws that secure the lamp housing.
      • The screws are captive and do not need to be removed from the lamp housing.
    3. Hitachi CP-X2010N Lens Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Work the projector housing loose from the two pins on the lamp housing.
    4. Hitachi CP-X2010N Lens Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the projector housing up from the left side and remove it from the case.
    5. Hitachi CP-X2010N Lens Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn the front lens element counterclockwise and lift it off the projector housing.
      • The front element will have lubricant on the inside shaft. Take care not to rub any of it off.
    6. Hitachi CP-X2010N Lens Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lens Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Inspect all glass elements for debris or damage.
      • Clean or replace the lens as needed.
Chance Kidd
crwdns2935283:009/20/22crwdne2935283:0
1.184 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 9-2, Watkins Fall 2022 crwdns2935289:0Austin Community College, Team 9-2, Watkins Fall 2022crwdne2935289:0
AUSTINCC-WATKINS-F22S9G2
crwdns2942667:0crwdne2942667:0 429
