Hitachi CP-X2010N Lamp Replacement
  1. Hitachi CP-X2010N Lamp Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement, Top Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement, Top Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the projector upside down to expose the screws on the underside.
  2. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
  3. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip projector right side up and orient it so you are facing the rear panel.
  4. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
    • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
  5. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
    • Remove the panel from the body of the projector.
  6. Hitachi CP-X2010N Lamp Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pinch the edges of the two blue connectors and pull upwards to remove them from the motherboard.
    • Carefully pinch and remove the small gray connector next to the blue wire opposite the speakers.
  7. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two black 14 mm screws securing the button array.
    • Move the wires for better access to the screws if needed.
  8. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bracket that was being held by the screw.
    • Take a picture or memorize its orientation for easier reinstallation.
  9. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the button array and network adapter out carefully.
    • Make sure all the wires connected to the array are unplugged.
  10. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the silver 10 mm screw securing the ground wire.
    • Keep the screw and washer in an easily accessible place.
  11. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the black 14 mm screw securing the motherboard to the case.
  12. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Delicately pinch and pull off all the wired connections surrounding the outside of the motherboard.
  13. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three orange cable locks. Then, you can safely pull the cables out.
    • Too much force could break the ribbon cable.
  14. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard out from the projector carefully so that it doesn't catch on any other components.
  15. Hitachi CP-X2010N Lamp Replacement, Lamp: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement, Lamp: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #2 screwdriver, loosen three silver captive screws from lamp housing.
    • The screws are captive and do not need to be removed from the housing.
  16. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the black 12 mm screw holding the housing to the lamp's brown power connector.
  17. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lamp from its housing.
    • You may need to use an iFixit opening tool to loosen the brown power cord from its connector.
  18. Hitachi CP-X2010N Lamp Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hitachi CP-X2010N Lamp Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inspect the lamp for debris or damage.
    • Clean or replace the lamp as needed.
Chance Kidd
crwdns2935283:009/20/22crwdne2935283:0
1,184 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 9-2, Watkins Fall 2022 crwdns2935289:0Austin Community College, Team 9-2, Watkins Fall 2022crwdne2935289:0
AUSTINCC-WATKINS-F22S9G2
crwdns2942667:0crwdne2942667:0 211
