Hipstreet Titan 2 HD Screen Replacement
  1. Hipstreet Titan 2 HD Screen Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the speaker is disconnected, the cover removal is complete.
  7. Hipstreet Titan 2 HD Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hipstreet Titan 2 HD Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hipstreet Titan 2 HD Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the hinges on the three ribbon connector clips and disconnect the ribbon connector.
  8. Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH#00 screwdriver, remove the three 0.145 inch circuit board screws.
  9. Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove battery, speaker and circuit board from screen.
    • Gently move circuit board assembly with speaker and battery away from device to ensure you do not damage the solder connections.
  10. Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use plastic opening tools to remove screen from front cover.
    • The screen is held in with plastic tabs.
    • Use of too much force on the screen may result in unwanted damage to screen.
    • To avoid damage to screen, ensure the metal screen cover does not catch on the plastic tabs.
  11. Hipstreet Titan 2 HD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screen solder connector with solder removal tool.
    • Solder new screen wire to circuit board with soldering tool.
crwdns2935229:05crwdne2935229:0
Jeffrey
crwdns2935283:003/11/15crwdne2935283:0
766 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 5-6, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 5-6, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S5G6
Your step 11 is irrelevant since this look like it is the wifi antenna.
The other end of this wire is not connected to the screen. I suggested removing gently the other end from the casing (it's held with adhesive) and so, no soldering at all to do.
Otherwise, great guide! Thanks!
kamen99 - crwdns2934203:0crwdne2934203:0
OK, so I cracked my screen and I cracked it today so I went on there to do the usual, you know? Well when I turned it on, my password lock started bugging out! (I thought a was being hacked) I am worried to do this (Step - Step thing) because I am just a child (NOT A SMALL ONE DON'T REALLY WORRY!) and my parents will be disappointed in me, I got this for my birthday! But this one is a white HipStreet tablet, one of those fancy new ones, I checked it out to see if it was actually a crack so I took off my screen protector and I felt it, but no, no! It was a crack but I couldn't feel it! I thought it was REALLY in the tablet, like through the hard-drive and wires and stuff like that, please help me I don't want to get in trouble, I can't really afford another one, and my parents say "You better protect this with your entire life, because if you break this one..YOU WON'T GET ANOTHER!" (I had 2 tablets along time ago, I broke them both, OH PLEASE I WAS A SMALL CHILD!) So please help me, Thank - You!
N3rD Al3rT - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 3,046
