Once you have disassembled the tablet cover, you can now access all of the internal components. This is a simple process and will require a replacement camera to complete.
Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
Place the small suction cup on your screen.
Insert the plastic opening tool between the screen cover and rear cover of the tablet.
Grasp the small suction cup.
Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
Pull upward on the small suction cup handle while sliding the opening tool.
Use the plastic opening tool to remove the speaker from the rear cover.
Once the speaker is disconnected, the cover removal is complete.
Use your plastic opening tool to lift the black ribbon connector lock.
Then, proceed to remove the camera.
Once the camera with the ribbon connector is removed, the process is complete.
