The camera could be broken from a fall or maybe when your screen cracked the camera was damaged as well. This guide will show the steps to easily replace the camera.
Remove the two 3mm screws using a PH00 screwdriver.
Use the blue plastic opening tool to gently pry the back case off.
Lift the tab on the wire ribbon shown here
Pull up gently on the camera housing shown on this picture, it is glued in place.
