The following will accurately show how to access the motherboard inside of the earbud charging case if it is in need of replacement due to damage from a possible collision or dropping of the case.
Use a spudger or other prying tool to gently pry open the case from the metal hinge that connects the white part of the top and bottom of the case together.
Using the spudger, going from the back of the case where the hinge used to be, pry the earbud charging housing up and remove it.
Use a Torx screwdriver to gently remove the six screws on the silver ring that holds in the motherboard and charging station.
Pull the silver bracket from the base of the case to reveal the motherboard.
Lift up and pull the motherboard out of the case.
