This guide will show you how to replace the speaker unit within one of the earbuds. This may be needed if the audio starts to fade or entirely cut out from the earbud itself along with other similar issues. For the guide, you will need a nylon plastic spudger.
Pinch the tip of the earbud in one hand while gripping the base of the earbud in the other.
Gently pull the tip of the earbud apart from the base.
Gently pull the battery out from the earbud housing to reveal the wire that connects the two.
Desolder the board connection to separate the red wire.
With the connection properly severed, pull the speaker unit out of the housing fully.
