In order to access the internal components of the Heyday Suitcase Turntable, you will need to remove the baseboard. The baseboard is what the platter sits on, as well as the arm and all of the external components of the device.
Before beginning this guide, turn off the record player and unplug the power cord.
Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
Use a metal spudger to pry the baseboard off of the case.
Disconnect the cords from the circuit board.
Remove the baseboard.
To reassemble your device, follow these instructions in reverse order. Reconnect the cords to their appropriate ports on the circuit board, then replace the baseboard by tightening the four screws.
