The Heyday On-Ear Wireless Headset can boost your spirits throughout the day, used for entertainment, work, chatting with friends, and more. The rubber on the headband provides comfort and ear protection. Over time, the rubber can get worn out or damaged and may need a replacement. If this is the case for you, the guide below will help you through the steps of replacing the rubber!
With one hand near the ear pad and the other hand on the headband, extend the headband to gain access to the screws.
Use a Phillips #0 screwdriver to remove the two screws.
Carefully peel away the rubber headband from from the headset.
