Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement, Ear-pad Cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement, Ear-pad Cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the headphones so that you can see the opening for the cushion. It should be along the outer edge where the cushion meets the plastic.
    • Take your IFixIt opening tool and place it between the cushion and the plastic to help you separate them.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be aware that the plastic tabs securing the cushion in place are susceptible to breaking. Use caution when using IFitIt tool when separating the cushion because damaging these tabs will result in difficulty reattaching the cushion.
  3. Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ear-pad cushion.
    • Once the cushion has been removed, you should see 4 black screws around the center of the speaker in the headphone.
    • Use a Phillips #00 to remove all 4 screws.
  4. Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are removed, turn the headphones over and remove the plastic cover on the outside. You should be able to see the motherboard under the plastic casing.
    • Be careful not to apply too much pressure to the plastic tabs.
  5. Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the single 2.4mm black screw from the motherboard.
  6. Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your IFitIt opening tool, release the the tab that that connects the motherboard.
    • Carefully disconnect the chip that connects the motherboard to the rest of the headphones.
  7. Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Heyday Active Noise-Canceling Wireless Headphones 0398 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plug in soldering tool and allow it to heat up.
    • Disconnect the motherboard by soldering the wires where they connect to the motherboard.
    • Once these are disconnected, the motherboard can be removed and replaced.
Christopher Puperi
crwdns2935283:009/13/23crwdne2935283:0
514 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 8-3, Watkins Fall 2023 crwdns2935289:0Austin Community College, Team 8-3, Watkins Fall 2023crwdne2935289:0
AUSTINCC-WATKINS-F23S8G3
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 214
