The hinges on your Heyday Active Noise-Canceling Wireless Headphones (model #0398) connect the earcups to the headband and allow them to fold and adjust comfortably while you move or listen to music. If your headphones no longer fold properly, feel loose, or one earcup won’t stay in place, use this guide to replace the damaged hinges.
This repair requires basic tools and careful handling of small screws.
Gently fold the headset to expose the 1.2 mm hinge screws.
Use a Phillips #00 screwdriver to remove the screws securing the hinge to the earcup.
Keep the screws in a safe place for reassembly.
After removing the screws, gently detach the hinge from the connected wire.
Insert the new hinge, making sure it aligns correctly with the existing components before reattaching it with the screws.
