Henry Hoover/Vacuum Cleaner PCB Bypass
crwdns2936621:0crwdne2936621:0
    • Make sure it unplugged from the mains.
    • Pull out the black clips on each side of the head.
    • Remove the 4 outer Phillips screws
    • Remove the cable reel from the top
    • Remove the 3 inner Phillips screws
    • Remove the plastic cover
    • Pull the PCB out of its slot inside the housing
    • Remove all of the wires from the PCB
    • Pull out the red High-Low switch and remove all of the wires
    • Remove the 2 wires from the on-off switch which connected to the rest of the vacuum cleaner.
    • Connect the 2 white wires from the motor to the green on-off switch.
    • Place the red high-low switch back in to its holder in the casing to fill the gap and prevent potential shocks.
    • Optionally, an indicator LED can be purchased online to fill the gap.
Jacob Dooley
crwdns2935283:005/23/22crwdne2935283:0
310 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 81
crwdns2942667:0crwdne2942667:0 381
