Heel Tip Replacement
  1. Heel Tip Replacement, Heel Tip: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Measure the size of your heel tips to know what size to purchase.
    • Most sizes are in the range of 8-13 mm. The variety packs are handy, especially if you have a few pairs to fix.
    • The size pictured in this fix is a 12mm heel tip on a size 9 heel.
  2. Heel Tip Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge a dull picket knife or jimmy between the top of the heel tip to help loosen and separate the tip.
    pincer pliers will also help to remove the metal part from the steel tube inside. Be careful not to pull the steel tube out. If the tip is quite worn down to the tube, you might need to drill out the heel pin
    Awethentique Pty Ltd - crwdns2934203:0crwdne2934203:0
  3. Heel Tip Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Heel Tip Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the heel tip with the pliers by twisting and pulling it out. Most can be turned counter clockwise to remove. Be careful not to pull only the rubber off.
  4. Heel Tip Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Heel Tip Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean the newly exposed tip of any debris.
  5. Heel Tip Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the pin end of the new tip into the heels opening.
    If you find the following cases:
    Heel Pin too thick: Grind down the pin carefully to make them fit
    Heel Pin too thin: You can hammer the pin on an avil to slightly flatten it out so that they fit snugly and can be hammered in, or twist some copper wire together and insert with the heel tip to make it thicker so that you can hammer it in snugly
  6. Heel Tip Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Heel Tip Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently tap the new tip in with the hammer. Careful not to damage the shoes material.
  7. Heel Tip Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Heel Tip Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Adjust the tip with the pliers to align the heel tip.
    What can I do if the original pin hole is too big for the replacement heel pins?
    Mary - crwdns2934203:0crwdne2934203:0
crwdns2935229:015crwdne2935229:0
Stephanie Shipman
crwdns2935283:001/22/17crwdne2935283:0
533 crwdns2915208:0crwdne2915208:0
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 crwdns2935289:0USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017crwdne2935289:0
USFSM-STEWART-S17S1G1
crwdns2931471:019crwdne2931471:0
crwdns2935297:022crwdne2935297:0
What if the replacement pins are too small for original pin hole in the heel?
I have just added a comment to help with this
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 110
crwdns2936753:030crwdne2936753:0 633
crwdns2942667:0crwdne2942667:0 92,985
