Health o Meter HDR743 Wire Connection Replacement
  1. Health o Meter HDR743 Wire Connection Replacement, Wire Connection: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a voltmeter to check for power in the wires.
    • If the power is on, the voltmeter will give a reading. Verify if the red indicator light is visible.
  2. Health o Meter HDR743 Wire Connection Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify where the issue in the wire begins.
    • If the problem isn't near a connection, use wire strippers to cut away the troubled area, and splice a new wire in-between.
    • If the troubled area cannot be found, the entire wire will need to be replaced.
    • Use a soldering iron to remove the wire from its connection to the circuit board.
    • Use wire strippers to remove the wires from the other components.
  3. Health o Meter HDR743 Wire Connection Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to solder and splice a new wire to the component.
    • The other end of the wire should be spliced or soldered directly to the circuit board.
  4. Health o Meter HDR743 Wire Connection Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Test the new connection with the voltmeter.
    • If the issue persists, the repair has failed, or a different component is faulty.
Dennis White Jr
crwdns2935283:004/02/18crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S1-G1, Kim Spring 2018 crwdns2935289:0University of Memphis, Team S1-G1, Kim Spring 2018crwdne2935289:0
UM-KIM-S18S1G1
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 243
