crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Hatch Restorecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Hatch Restore Teardown, Intro: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Intro: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This device isn't hard to repair. Just keep track of your screws.
    • You will only need a PH1 screw driver for this entire teardown.
  2. Hatch Restore Teardown, Rubber Feet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, Rubber Feet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, Rubber Feet: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber feet from the bottom of the device.
  3. Hatch Restore Teardown, Bottom Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Bottom Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these 8 screws.
    • You may need to remove adhesive from the screws before you can remove them.
  4. Hatch Restore Teardown, Bottom Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Bottom Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the bottom cover off using a pry tool.
  5. Hatch Restore Teardown, Buttom Circuit Board Screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Buttom Circuit Board Screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 screws from the circuit board.
  6. Hatch Restore Teardown, Bottom Circuit Board Power Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Bottom Circuit Board Power Cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the power connector from the circuit board.
    • Do not pull the circuit board too far away from the device. There is a ribbon cable on the bottom.
  7. Hatch Restore Teardown, Bottom Circuit Board Ribbon Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Bottom Circuit Board Ribbon Cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the black tabs on the ZIF connector towards the cable, then remove the cable.
    • The cable should have no resistance when pulled out. Do not forcefully remove the cable.
  8. Hatch Restore Teardown, Outer Button Ring: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, Outer Button Ring: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, Outer Button Ring: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the outer button ring using a pry tool.
  9. Hatch Restore Teardown, Outer Ring Screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Outer Ring Screws: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 2 screws from both sides of the device, 4 screws total.
  10. Hatch Restore Teardown, Outer Ring Tabs: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, Outer Ring Tabs: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, Outer Ring Tabs: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release the tabs around the ring.
    • Remove the light diffuser.
  11. Hatch Restore Teardown, LED Array: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, LED Array: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, LED Array: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After disconnecting the ribbon cable, we can inspect the LED array.
    • It has both warm and cold colored LEDs.
    • There is a weight glued in below the LED.
  12. Hatch Restore Teardown, Inside Panel Screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Inside Panel Screws: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these 7 screws.
  13. Hatch Restore Teardown, Motherboard Audio Cable: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Motherboard Audio Cable: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The panel feels heavy and weighted. There is also a weight glued in under the LED array, seemingly in an attempt to make the device feel more premium.
    • Disconnect the audio cable
  14. Hatch Restore Teardown, Motherboard: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hatch Restore Teardown, Motherboard: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here we can see the motherboard. It has an ESP32 processor.
    • There is a blank area that could possibly hold a second ESP32
    • There is also a 32GB MicroSD card
    • To remove the MicroSD card, stick your nail into the slot on the metal latch, and slide it towards the ESP32.
    • The MicroSD card contents can be found here.
  15. Hatch Restore Teardown, Speaker Assembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, Speaker Assembly: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hatch Restore Teardown, Speaker Assembly: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4 screws holding the speaker assembly in place.
    • The speaker assembly is fused, and should not be opened.
9021007
crwdns2935283:007/13/18crwdne2935283:0
4,599 crwdns2915208:0crwdne2915208:0
crwdns2935297:025crwdne2935297:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 3,635
