There are no previous steps needed. All that is required is a #0 Phillips Screwdriver, (2) fresh AAA batteries, and a few minutes of time.
Unscrew the (2) #4 Phillips head 8 mm screws on the back cover using a Phillips #0 screwdriver. The screws are captured and do not need to be completely removed from the back cover.
The batteries are now accessible. Remove batteries using fingers or plastic spudger.
Mi BOP it ! No funciona
Wonder what happened? Did you take it apart?
uh can you do one for the 2016 bop it
