If the buttons on your device aren't working, it may be time to replace your control board. Follow this guide to do so.
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Remove the five 14.4 mm T10 Torx screws.
Gently pull the front apart from the back.
Remove the four wires connecting the front and back panels.
Pinch the connector tab and pull gently upwards.
Repeat for the other three connectors.
Pull the silicone button band off of the outer edge of the speaker.
Disconnect the two pressure connections from the circuit board.
Gently remove the control board band by placing fingers in contact with it through the button openings.
crwdns2947412:09crwdne2947412:0
Do you guys know where to get a control board, because my board is broken so i am looking for one
Where to get control board onyx 2.
My on/off button keeps blinking…..would somebody please email me cause I am a techno nitwit……..i’m gonna bring this piece of non chargeable crap outside and go Italian on it with the 12 gauge! SERENITY NOW!
Sincerely,
email ; jorcal3318@aol.com
power button continually blinks. Won’t turn on, can’t pair, no other action can be taken, just the blinking power button. what’s the solution? Please share….
Speaker plays for split second then fades away like wtf
