Harman Kardon Esquire Mini Speaker Replacement
  1. Harman Kardon Esquire Mini Speaker Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Speaker Replacement, Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the motherboard by removing 4 screws around the perimeter of the motherboard. Keep in mind the wires still attached to the speakers, so pull gently.
  4. Harman Kardon Esquire Mini Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH0 screwdriver unscrew the screws, there is one 4 mm screw on each speaker.
    • Re-do the same steps above for the other speaker to remove it.
  5. Harman Kardon Esquire Mini Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker by using the plastic opening tool. Apply a gentle upward force to remove it.
crwdns2935229:015crwdne2935229:0
yousef aljeemaz
crwdns2935283:010/18/17crwdne2935283:0
1 039 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G9, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G9, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G9
crwdns2947412:040crwdne2947412:0
Where can i buy a new speaker for this sound box ? thanks… sizinojr@gmail.com
Sizino Santos - crwdns2934203:0crwdne2934203:0
Did you ever find the replacement speaker? I need one too.
Thx.
Troy -
Thanks, I need speaker also, where can I buy.
mnyucel@yahoo.com
mnyucel - crwdns2934203:0crwdne2934203:0
Hi, I also need to know where could get new replacement speaker.
Thanks
mezafernando23 -
Hi, I also need to know where could I get the replacement speaker.
Thanks
mezafernando23 -
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 177
crwdns2942667:0crwdne2942667:0 21,045
