Harman Kardon Esquire Mini External Stand Replacement
  1. Harman Kardon Esquire Mini External Stand  Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini External Stand  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini External Stand  Replacement, External Stand: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Pentalobe screw driver, unscrew the 5.1 mm screws by applying a clockwise force.
    • Remove all of the 5.1 mm screws, and slowly lift the stand. There are 4 screws on the stand.
    • After the stand is removed, replace the stand with a new one.
yousef aljeemaz
crwdns2935283:010/18/17crwdne2935283:0
1,039 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G9, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G9, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G9
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 657
