Harley-Davidson Fatboy Lo Battery Replacement
  1. Harley-Davidson Fatboy Lo Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harley-Davidson Fatboy Lo Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw using the flathead screwdriver.
    • Following removal of the screw, lift the seat from the rear and then carefully pull the seat towards the back of the bike removing it.
  2. Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is located at the center of the frame, directly beneath the seat.
  3. Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To disconnect the terminals you will use a ratchet and 10mm socket to remove the bolts, then remove the wires from each terminal.
    • Be sure to disconnect the ground before the positive connection. (Note: the positive is covered by a red plastic cover, this must be removed to expose the terminal.)
  4. Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the wires are disconnected from the terminals carefully remove the battery, by grasping the battery and gently lifting from its base.
  5. Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the positive terminal is on the left side of the bike and the negative terminal is on the right.
    • Gently place the battery back onto the base avoiding any wires.
  6. Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reconnect the terminals by placing the wires over the designated terminals.
    • Positive before Ground.
    • Once the wires are in place tighten the screws back in place using the ratchet wrench and 10mm socket.
  7. Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cover the positive terminal with the red plastic covering provided.
  8. Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Harley-Davidson Fatboy Lo Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To replace the seat, place the metal tab, on the bottom side at the front of the seat into the slot at the base of the fuel tank.
    • Ensuring the tab is in place, repeat step 1 in reverse to reinstall the seat.
This is a comprehensive guide that walks through the removal of the old battery to the installation of the new.
Austin Stone
crwdns2935283:003/31/20crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S5-G16, Willis Spring 2020 crwdns2935289:0University of Memphis, Team S5-G16, Willis Spring 2020crwdne2935289:0
UM-WILLIS-S20S5G16
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 122
crwdns2942667:0crwdne2942667:0 11,382
