Replacing the hard drive on this device is quite easy as all of the components are accessible by removing a single cover.
First, turn off your laptop, then disconnect the power supply. Unplug any peripheral devices connected to your laptop.
Next, remove the battery from the laptop.
Next, remove the 4 Phillips screws from the service door cover (circled in red).
Remove the 4 screws circled in red in the photo.
Once the screws are removed, slide the hard drive to the right, with the help of the tab.
Remove the 4 screws located on the side of the support.
Then, remove the hard drive form its metallic support.
Finally, replace de hard drive with a new one or an SSD.
To reassemble your device, follow these steps in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2958738:0crwdne2958738:0 ›
why do you do this?
Carl Jefferson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You can do this to replace a faulty hard-drive or replace it by a SSD to get better performance. So I did this to replace mine by a new one and I wrote this guide for other people who search how to do it. As you can see, very easy to do.
Brendan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Amazing tutorial, thanks :)
Jérémy Martin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
