This guide is for replacing the hard drive on a Gateway LT2104u Laptop.
Use a Phillips #0 screwdriver to loosen the screws.
To open the panel, use a plastic opening tool or your finger.
Use the Phillips #0 screwdriver to unscrew the two 5mm screws.
Remove the hard drive by using your fingers to pull firmly on the clear tab.
You have successfully removed the hard drive from the laptop.
