Hard / Factory Reset
crwdns2936621:0crwdne2936621:0
  1. Hard / Factory Reset, Hard Reset - Method One:: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hard / Factory Reset, Hard Reset - Method One:: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hard / Factory Reset, Hard Reset - Method One:: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Switch off the phone.
    • Pres the Power button and when you feel a vibration release it and press and hold the Volume Up button.
    • From Boot mode menu select [Recovery mode] (use Volume Up for navigation and volume doun for OK).
    • Now you are in the known Android System recovery menu. Use again the Volume Up for navigation and the Volume Down for OK and select one by one: wipe data/factory reset - Yes -- delete all user data - reboot system now.
    • Tis will reboot the device and will restore to its default settings.
    I did the second method and its saying no command
    loberets - crwdns2934203:0crwdne2934203:0
    After factory reset, the Medion Tablet-E10714 MD 60216 still ask for (the unknown) pincode before
    factory reset. The waittime between two attems is 950 seconds !!!!!!
    Clear eMMC and Wipe cache partition this not solve this problem.
    Anton Broos - crwdns2934203:0crwdne2934203:0
  2. Hard / Factory Reset, Factory Reset - Method Two: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hard / Factory Reset, Factory Reset - Method Two: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hard / Factory Reset, Factory Reset - Method Two: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the Power button and wen you fill the vibration, release the Power button and press and hold the Volume Down button.
    • Now the device is in Factory mode. Use the Volume Up/Down buttons for movement and the Power button for OK and select Clear eMMC.
    • That's all. The phone will reboot and will be restored to a factory settings.
    • Did you do it successfully?
    Um I just did what you said we should do, but now my phone just turns on to a black blank screen.
    Help please
    Arthur Irons - crwdns2934203:0crwdne2934203:0
    IF A DO THAT THE IT JUS TELLS ME THE eMMC IS BUSY CAN’T FORMAT.
    Sonja Grobler - crwdns2934203:0crwdne2934203:0
    After doing that it ask for a google account which I don't know
    enock Msanzu - crwdns2934203:0crwdne2934203:0
    Yes but after that my sim card lost network
    zawadi pascal - crwdns2934203:0crwdne2934203:0
    My sim card stop working after clear emmc
    I did it, but in order to use the phone,I'm required to put in the previous pattern or sign in with email.
    I inserted the previous pattern but it say incorrect.
    What to do?
    Ohsee sirleesue - crwdns2934203:0crwdne2934203:0
    Yeah I have used this method before. It worked but this time it says” eMC is busy can't format” . What do I do ?
    Benjamin Ansah - crwdns2934203:0crwdne2934203:0
    It says the emmc is busy and can't format
    Gift Kapito - crwdns2934203:0crwdne2934203:0
    I've done as instructed, after rebooting it gets stuck on the logo "mecer". Does not require any other info
    Innocent Sithembiso Mncube - crwdns2934203:0crwdne2934203:0
    I can get to the boot screen, but no matter what selection I make, it just gives me a solid black screen.
    Jess - crwdns2934203:0crwdne2934203:0
crwdns2935229:024crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194.598 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01.702crwdne2935297:0
crwdns2947412:022crwdne2947412:0
great simple clear instructions - did exactly what you said - phone back up and running good as new! Thanks. M
Marty - crwdns2934203:0crwdne2934203:0
Thanks. The phone has reset.
melandart - crwdns2934203:0crwdne2934203:0
“eMMC is busy can't format, please retry”
What do we do?
richterrea - crwdns2934203:0crwdne2934203:0
Today I also met this message. How did you solve this problem? Thanks, Zoltan (HUN)
Zoltán Bocskai -
HI!, I did the “clear eMMc” method but still my MePop_V03 phone still stock on logo screen.
what should I do?
Please help me .thanks in advance God bless
Herbert Redondo - crwdns2934203:0crwdne2934203:0
Same problem I have, did you find another way to fix it?
Hi…I did the clear emmc method and my sim card stop working after doing this what should I do.kindly help me thanks in advance
Does not remove the google account synchronized
Mill Lilan - crwdns2934203:0crwdne2934203:0
I can’t select any of the options. the volume up and down both move between the selections, I can’t seem to select.
lila davidson - crwdns2934203:0crwdne2934203:0
Do ypu mean thet it “skips” one selection and you have to double press to make it move?
Daniele Carminati -
After i have done that is still writing emmc is busy
Ayoola Lawal - crwdns2934203:0crwdne2934203:0
My phone shows no comand when I try to do the above process
Nomyongo Michael Ushahemba - crwdns2934203:0crwdne2934203:0
If anybody fixed the busy emmc error , please help me
Divyanshi Tripathi - crwdns2934203:0crwdne2934203:0
Formating but it says bootdev is busy can't format, please try again
Lea Mae - crwdns2934203:0crwdne2934203:0
Lefagy. Nincs benne SIM kártya. Ez lehet probléma?
Varga Sándor - crwdns2934203:0crwdne2934203:0
Hi i have been facing this issue, eMMC is busy can't format, please retry.
What do i do? Kindly help 🙏
Vaanmayi Chitti - crwdns2934203:0crwdne2934203:0
Bouton d'allumage+ volume bas pour rallumage. Constat: Allumage, écran en chinois. Volume bas, sélection EMMC , bouton "POWER" pour valider. Mais rien. Le bouton power ne semble pas fonctionner. Ecran toujours pareil en chinois. Après sélection EMMC, rien.
mon mail si vous avez la solution: cathy.rosier@gmail.com . Merci.
Cathy - crwdns2934203:0crwdne2934203:0
Kso I've tried multiple different ways to unlock my device when I hold the volume up button with power it brings me to the the picture it shows up there , there's absolutely nothing wrong with my devices buttons but it still won't let me select "wipe data/factory reset"
When I hold volume down/power it brings me to some Chinese menu which I have no clue what it says or does please help me
My device IMEI number says it's Samsung galaxy S21 ultra but then in the YouTube tutorials it's a completely different phone then what I have I think when it powers on it just says" android "
I bought this device online and when I got home and was bout to put my sim card in it it had a pin code on it so I've been trying to unlock it myself.
It does unlock after everytime I turn it on/off but after a few minutes it glitches out and locks me out again even though I've tried putting a new pin code on it I've tried to go to settings and factory reset that way but at the last " erase phone" or w.e it won't let me select it.
krishaedwards97 - crwdns2934203:0crwdne2934203:0
K so If someone can just help me understand what the Chinese menu means or just help me to factory reset my device, like whenever it locks me out again on the screen it says " privacy something on the lock screen
Take picture and use google translate. I think you bought a fake phone unfortunately. Lyca Mobile sim cards work in these fake phones that often run on 2g networks from the 90’s. Best is to buy the same phone with cash and get apple care. Wait 1 day, disable battery on fake phone and take it back to apple as defective and see what happens. Change sime card trays out if possible.
Csak -
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 222
crwdns2942667:0crwdne2942667:0 51,955
