Hannspree SN12E2 Speaker Replacement
  1. Hannspree SN12E2 Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Speaker Replacement, Touchpad Plane/Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 Speaker Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree SN12E2 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
  8. Hannspree SN12E2 Speaker Replacement, Speaker: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree SN12E2 Speaker Replacement, Speaker: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws on the speakers.
  9. Hannspree SN12E2 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the JST connector by pulling parallel to the housing .
    • When replacing the connectors ensure that they are oriented correctly. The housing is keyed to prevent the connectors from being plugged in backwards.
  10. Hannspree SN12E2 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat same steps for other speaker if necessary.
Tim Chase
crwdns2935283:003/25/19crwdne2935283:0
363 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 crwdns2935289:0UMass Dartmouth, Team S2-G2, Simcock Spring 2019crwdne2935289:0
UMASSD-SIMCOCK-S19S2G2
crwdns2942667:0crwdne2942667:0 172
