Hannspree SN12E2 RAM Replacement
  1. Hannspree SN12E2 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree SN12E2 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the RAM access door.
    • Remove the two 3mm screws using a Phillips #0 screwdriver.
    • Gently lift on the door out of place.
    • When replacing the door it should click into place. Ensure the alignment tabs are correctly seated and gently push until it clicks into place.
  5. Hannspree SN12E2 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently push outward on the two retaining clips, being careful not to damage the motherboard.
    • Lift up on the RAM until it makes a 35 degree angle with the board.
    • Remove the RAM by pulling away from the housing at 35 degrees.
Tim Chase
crwdns2935283:003/25/19crwdne2935283:0
363 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 crwdns2935289:0UMass Dartmouth, Team S2-G2, Simcock Spring 2019crwdne2935289:0
UMASSD-SIMCOCK-S19S2G2
crwdns2942667:0crwdne2942667:0 406
