Hannspree SN12E2 Fan/Motherboard Replacement
  1. Hannspree SN12E2 Fan/Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Fan/Motherboard Replacement, Touchpad Plane/Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
  8. Hannspree SN12E2 Fan/Motherboard Replacement, Fan/Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 3.4mm PH0 retaining screws as well as the three 3mm PH0 fan screws
  9. Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug all pictured connectors
  10. Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree SN12E2 Fan/Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard from the housing place it on a flat surface.
    • Flip over the motherboard so that the heat pipes ae face up.and disconnect fan JST Connector, pictured in red
Brianna Johnson
crwdns2935283:003/21/19crwdne2935283:0
443 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 crwdns2935289:0UMass Dartmouth, Team S2-G2, Simcock Spring 2019crwdne2935289:0
UMASSD-SIMCOCK-S19S2G2
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 440
