Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement
  1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
  10. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Front and Rear Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Front and Rear Camera Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the ribbon connecter attached to the camera and where it connects to the circuit board.
    • The two cameras are connected with one ribbon cable.
    • Zero insertion force connector.
  11. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the sliding zero insertion force (ZIF). Use the plastic opening tool or a fingernail to slide the tab out, then pull the cable out.
  12. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the cameras out of their resting places in a straight upward motion.
  13. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the speakers.
    • Use a pair of tweezers to peel the adhesive tape holding the speaker wires down.
  14. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the red and black wire to the left and the right of the ZIF connector.
    • Remember the placement of both wires.
    • Both the soldering iron and the wires will be hot.
  15. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the right and left speaker.
matthew vandeventer
crwdns2935283:003/11/15crwdne2935283:0
950 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 9-4, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 9-4, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S9G4
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 476
