crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Remove the outer screen cover by releasing the top clip from the main body of the device.
Pull out the stylus from the top right corner of the device.
Slide the memory cartridge cover up and off the device.
Remove the battery cover by releasing the clip from the main body of the device.
Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99-
Disconnect the flex strip from the motherboard with tweezers.
Release the latch in bottom right corner of the touchscreen.
