Use this guide to replace the Motherboard.
Remove the outer screen cover by releasing the top clip from the main body of the device.
Pull out the stylus from the top right corner of the device.
Slide the memory cartridge cover up and off the device.
Remove the battery cover by releasing the clip from the main body of the device.
Remove the batteries from the device.
Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
Disconnect the flex strip from the motherboard with tweezers.
Use tweezers to remove the power button from the back case.
Disconnect the button pad by using the spudger to pry it off the motherboard.
Remove the button pad.
Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
Use the spudger to lift the motherboard from the case.
