Handset Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Handset Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Handset Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery cover by placing your thumb on the cover and gently push towards the base of the phone.
  2. Handset Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rechargeable battery pack (BP-T18) by pressing down on the power cable connector and pulling at the same time.
  3. Handset Replacement, Handset: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
    • Product is made of brittle plastic.
  4. Handset Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Handset Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
    • The opening should become bigger if you exert force at a 30 degrees angle.
    • Increase the degree of slant until the back cover is completely removed.
  5. Handset Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Handset Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
    • Use a screwdriver to remove all 3 screws.
Caleb Thomas
crwdns2935283:009/29/16crwdne2935283:0
161 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Harley Fall 2016 crwdns2935289:0IUPUI, Team 3-3, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S3G3
crwdns2935297:017crwdne2935297:0
crwdns2942667:0crwdne2942667:0 77
