This will walk you through replacing the microphone on the handset.
After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
Increase the degree of slant until the back cover is completely removed.
After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
Use a screwdriver to remove all 3 screws.
Locate the rubber part towards the very bottom of the handset. This is the microphone with protective rubber cover.
Remove the protective rubber cover. This may require a spudger.
