Hand Painting a Car
  1. Hand Painting a Car, Hand Painting a Car: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hand Painting a Car, Hand Painting a Car: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the proper safety gear when sanding. Full length clothing, a painter's mask and eye protection should be worn to prevent irritation or injury.
    • Remove all the headlights and tail lights so that the paint matches on the edges of the body. Cover any holes that you don't want to become dusty and painted.
  2. Hand Painting a Car: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hand Painting a Car: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hand Painting a Car: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a power sander with a low-grit sand paper to strip the old paint off the surface of your vehicle. Use a sanding block or just the sand paper to reach small or hard-to-get places.
    • Make the first pass with at least 100 grit, possibly even as low as 40 grit sandpaper. Coarser grits will remove the paint efficiently, but leave a very rough finish.
    • Make a second pass with finer sandpaper (200 grit), to reduce the scratches and smooth out the body.
    • Repeat the procedure with 400, 800, and 1500 grit sandpaper to make the car's surface super-smooth. Spend a good amount of time with each grit, as it will be much harder to remove the deep scratches down the line.
    • Wipe off the sanding dust occasionally to help speed the sanding process.
  3. Hand Painting a Car: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have stripped the paint off all the parts that you wish to paint, rinse them with water and wipe them down with a clean lint-free cloth so the paint will stick.
    • Cover all parts of the car that you don't want to be painted using masking tape and/or double sided tape with drop cloth. This includes lights, windows, mirrors, grills, tires, the ground/any close-by surfaces, etc.
  4. Hand Painting a Car: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hand Painting a Car: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hand Painting a Car: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make a mixture of 50% Rustoleum paint, and 50% mineral spirits. The paint will be very, very thin.
    • If you over-apply the paint, it will run down the sides! Over-applying the paint will negate all the hard work you put into prepping the car for painting. If it happens, use a rag doused with pure mineral spirits to wipe off the runs.
    • Apply several thin coats of paint onto the car. Wait approximately 30 minutes between each coat to allow the paint to partially dry.
    • You will probably have to apply at least five thin coats of paint before the body (especially the Bondo areas) are no longer visible. Don't rush, and don't over-apply the paint.
  5. Hand Painting a Car: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hand Painting a Car: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hand Painting a Car: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the paint has fully dried, inspect it for cracks, runny spots, or any imperfections.
    • Smooth out any imperfections by wet sanding with water and 1500 grit sand paper.
crwdns2935229:030crwdne2935229:0
crwdns2947412:013crwdne2947412:0
WOW I can't believe you rolled it after you did all that work to sand and mask off everything. How did it come out? You must have done a lot of 600 to smooth it all out. Do yourself a favor, go to Harbor Freight, get a spray gun and compressor. People Please don't use a brush!!! roller is much better but will leave bumps.
JonnyGood - crwdns2934203:0crwdne2934203:0
It worked fine for me, @%^$$@$.
neilriggers -
If memory serves, the optimum pressure for a spray gun is about 25 psi and the optimum distance is a foot (300mm) and when doing so, you need to DIRECT spray the panel, which isn't necessarily easy with all the angles etc. For the top coat, I found using a wide fan spray to be best, which resulted in the least number of imperfections, but you need to remember, your local environment WILL affect it, a dust free spray room is obviously the best, but thats not always available
gaisasanktejo - crwdns2934203:0crwdne2934203:0
I might try this if I ever buy a cheap beater just to test it lol
Michael Kimmel - crwdns2934203:0crwdne2934203:0
YOU are Awesome.This Article is really awesome.the way of explanation is great.I am also working on similar website,I would be vary thankful to you if you likes to visit my website as well.Here is the link of my website.
www.carhow.net
car how - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 134
crwdns2936753:030crwdne2936753:0 507
crwdns2942667:0crwdne2942667:0 149,992
