Hamilton Galileo Ventilator Power Supply Replacement
  1. Hamilton Galileo Ventilator Power Supply Replacement, Opening the Column in the Hamilton Galileo: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Hamilton Galileo Ventilator Power Supply Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Hamilton Galileo Ventilator Power Supply Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Galileo Ventilator Power Supply Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
  4. Hamilton Galileo Ventilator Power Supply Replacement, Power Supply: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Galileo Ventilator Power Supply Replacement, Power Supply: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all cables connecting power supply to GALILEO.
    • To remove the main power connector, squeeze on the two points indicated in the second picture.
    • Remove the rear cover and place it on a suitable surface.
  5. Hamilton Galileo Ventilator Power Supply Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the retaining strip securing the power supply in its housing.
  6. Hamilton Galileo Ventilator Power Supply Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the power supply out from its housing.
  7. Hamilton Galileo Ventilator Power Supply Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Galileo Ventilator Power Supply Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To install the new power supply, simply do steps 5-2 in reverse.
    • Make sure the security clamp (shown in picture) is tight before reinstalling power supply.
    • Perform the internal voltage test linked here: page 7-5 of Section 7.3, Checking voltages.
    • If this test is not successful, it is likely that there is a loose connection somewhere between the internal power supply and the printed circuit boards. Check the wires to make sure they are securely fastened.
    • When the above test is successful, continue with the tests in the following sections:
    • 1) Section7, Checking hardware, voltages, and interface
    • 2) Either: Section 9, Running Original Upgrade 1 test software OR Section 10, Running Upgrade 2 test software
Ian Van Sciver
crwdns2935283:004/09/20crwdne2935283:0
332 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G26, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G26, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G26
crwdns2942667:0crwdne2942667:0 752
