For more information on replacing the inspiratory valve, please refer to section 10 in the service manual.
Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
The Standoff Brackets (C) remain with the Main Cover.
Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
Remove Safety Valve Block
1. Disconnect the cable from the Ambient Valve Solenoid
2. Disconnect the Shaped Hose (A)
3. Remove the 2 Hex Allen Screws (B)
4. Remove the Safety Valve Block
To remove Ambient Valve Solenoid: Unscrew the Ambient Valve Solenoid (C) form the Safety Valve Block
Removing the Inspiration Valve
1. Disconnect the tubing and cables form the Inspiration Valve
3. Remove 2 Hex Allen screws (B) M5x60
4. Move the Inspiration Valve forward and then up
5. Remove the Inspiration Valve
crwdns2935103:0crwdne2935103:0
wow great manual! very helpful and informative!
