Hamilton Beach 70740 Motor Replacement
  1. Hamilton Beach 70740 Motor Replacement, Bowl and Lid: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 70740 Motor Replacement, Bowl and Lid: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Motor Replacement, Gears: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 70740 Motor Replacement, Gears: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the nylon spudger to remove the plastic screw covers.
  3. Hamilton Beach 70740 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 70740 Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 70740 Motor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a #2 Phillips head screwdriver, remove the four 10 mm screws and pull the shaft straight upwards to uncover gears.
  4. Hamilton Beach 70740 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 70740 Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grasp center piece of gear mechanism and pull straight upward.
  5. Hamilton Beach 70740 Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 70740 Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws and pull the rubber suction cups straight up.
  6. Hamilton Beach 70740 Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 70740 Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 70740 Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the heavy duty plastic spudger remove the four rubber caps.
    • Using a #2 Phillips head screwdriver, remove the four 11 mm screws inside each of the bases legs.
    • Pull the base straight up to remove it from the processor.
  7. Hamilton Beach 70740 Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 70740 Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 70740 Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
    • From the open base pull the motor straight out.
  8. Hamilton Beach 70740 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 70740 Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor.
    • Using the wire stripper crimping tool strip the ends of each of the black cords and insert them into the opposite ends of a parallel connector, then crimp firmly.
    • Using the wire stripper crimping tool cut the four red wire connections from the switch to the motor and then rewire the four red wires together in a wiring connector cap.
    • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
Travis Williams
crwdns2935283:002/02/17crwdne2935283:0
552 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-4, Blackwell Spring 2017 crwdns2935289:0USF Tampa, Team 17-4, Blackwell Spring 2017crwdne2935289:0
USFT-BLACKWELL-S17S17G4
crwdns2942667:0crwdne2942667:0 3,365
