Replacement of the drive gears. Do not remove grease as it helps the gears move smoothly.
Turn the bowl counterclockwise and lift.
Use the nylon spudger to remove the plastic screw covers.
Using a #2 Phillips head screwdriver, remove the four 10 mm screws and pull the shaft straight upwards to uncover gears.
Firmly grasp center piece of gear mechanism and pull straight upward.
