After using this guide you will have learned how to replace the rotor to your blender. You will need to use basic tools to complete this guide.
Remove the container from the blender.
Hold the blender and the container, then twist the container in a clockwise motion.
Turn the blender so the bottom is facing you.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
Unhinge the plastic motor platform from the blender.
Using a spudger, carefully insert the tip into the coil of wire around motor.
Remove the white rotor piece by rotating it counter-clockwise.
Hi, Any idea where to get a new rotor.
Hey! did you got the rotor?
Cómo puedo retirar la pieza blanca del rotor,si está bien socada , apretado,como detengo el rotor no de vuelta gracias
