After using this guide you will learn how to replace the blades in your blender. You will need to use basic tools to complete this guide.
Remove the lid from the container by holding the base and pulling up on the lid.
Remove the container from the blender.
Hold the blender and the container, then twist the container in a clockwise motion.
Using a pair of pliers to hold the blade in place, use your other hand to unscrew the rubber piece on the bottom of the container.
Remove the rubber piece and the two washers by rotating the rubber piece counter-clockwise.
Using the pliers, remove blades and the washer around the blade shaft.
To reassemble your device with the new blade assembly, follow these instructions in reverse order.
Need to know how to install parts and how many
papi3701@aol.com - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Looks like I missed parts need to know the order son cuantaty
For my 501101B blender, the whole blade assembly popped out, so the blended smoothie draws at the bottom like a water falls How to fix this?
Joyful Joy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
