Hamilton Beach 25460Z Top Heating Element Solders Replacement
  1. Hamilton Beach 25460Z Top Heating Element Solders Replacement, Handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 25460Z Top Heating Element Solders Replacement, Handle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug your device before proceeding with disassembly.
    • On the back of the press, remove the locking washer by prying upwards with the nylon or metal spudger tool.
    • Repeat for the other washer across from the first one.
  2. Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using any long, thin object, push the 43mm bolt from the inside towards the outside to expose the end of the bolt.
    • Pull the end of the bolt out to completely remove it.
    • Repeat for the second bolt.
  3. Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the 4.0mm Allen Wrench, unscrew the two 26mm bolts connecting the handle to the upper heating element housing on both sides.
  4. Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the locking knob all the way to remove it.
  5. Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the locking knob couple down to the base of the handle, then pull up on the free end of the handle. It will easily pop off.
  6. Hamilton Beach 25460Z Top Heating Element Solders Replacement, Top Heating Element Solders: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently separate the heating element housing from the cooking surface by pulling up on the housing and pushing down on the surface.
    • Pulling too far or too hard can break the delicate internal wiring.
  7. Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the underside of the housing, use the PH2 Screwdriver to remove the single 12mm screw to disconnect the LED tray.
    • The housing can now be completely removed.
  8. Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 25460Z Top Heating Element Solders Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The left lead needs to be connected to the two red wires.
    • The right lead needs to be connected to the two white wires.
    • One or both of the leads can have damaged solder, resulting in poor connections between the lead and the wire ends.
    • De-solder the existing solder joints on the lead(s).
    • Solder the wire ends back to their corresponding leads.
    • Refer to this page if you need to brush up on your soldering skills.
Katie Howes
crwdns2935283:002/01/15crwdne2935283:0
276 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-27, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 6-27, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S6G27
crwdns2942667:0crwdne2942667:0 1,726
