Hamilton Beach 22794 Disassembly
  1. Hamilton Beach 22794 Disassembly, Hamilton Beach 22794: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly, Hamilton Beach 22794: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly, Hamilton Beach 22794: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the crumb tray from the back of the toaster.
    • It may require a firm tug on the tray.
  2. Hamilton Beach 22794 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the toaster on it's side and unscrew all 6 Phillips #0 screws from the bottom housing.
    • The first 5 are all 12.5mm screws
    • The last screw is on the left side and measures 10 mm.
    • One of the screws is of a different color on the LEFT side.
  3. Hamilton Beach 22794 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bottom housing of the toaster.
    • This may require a small plastic spudger if it's not easily coming apart.
  4. Hamilton Beach 22794 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As you're removing the bottom, make sure to move any brackets out of the way and unclip the white cable.
    • Pull the cable firmly up & out to free it from the clips.
  5. Hamilton Beach 22794 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lay the bottom housing down and unscrew the 10 mm screws securing the small white bracket with a Phillips #0 screwdriver.
  6. Hamilton Beach 22794 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Go to the front of the toaster to remove the large square handle.
    • This requires a firm tug and possibly a slight twist to free it from the metal rod.
  7. Hamilton Beach 22794 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the bottom housing and the handle are removed, you can pull up on the central unit and remove it from the top housing.
    • You may need to wiggle this unit to free it from any snagging/catching.
  8. Hamilton Beach 22794 Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removal, you will see two small wires plugged in to a board.
    • Firmly pull up on these wires to unplug.
  9. Hamilton Beach 22794 Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two Phillips #0 7 mm screws that secure the metal backing to the circuit board.
    • Remove the metal backing.
    • Unscrew the two 5 mm Phillips #0 screws and remove the board.
  10. Hamilton Beach 22794 Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your metal spudger, unfold the metal bracket and unhook the spring so that you can free the press-down mechanism.
  11. Hamilton Beach 22794 Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the other springs on the size and pull up on the metal rod to free the push-down mechanism from the center part.
  12. Hamilton Beach 22794 Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hamilton Beach 22794 Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your metal spudger, unfold the metal tabs holding the bread-holding trays in place.
    • Pulling up, remove the bread-holding metal trays.
  13. Hamilton Beach 22794 Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that we know how to dissaseble the toaster, it's valuable to learn a little bit about how it functions:
    • The toaster constantly receives power when it's plugged in, but the electrical circuit remains inactive until you push down the handle.
    • Pushing down the handle causes two switches to close, completing the circuit and activating the toaster's power source.
    • The circuit breaks when a certain power level is reached in the timing chip on the circuit board. This signal weakens the electromagnet, releasing the handle and popping up the bread trays.
    • A potentiometer, linked to the control knob on the front of the device, regulates power flow to the chip.
    • Setting to maximum (level seven) restricts the power flow, prolonging toasting. On the other hand, choosing cancel reduces resistance, quickly ejecting the toast.
Alex Beattie
crwdns2935283:009/13/23crwdne2935283:0
267 crwdns2915208:0crwdne2915208:0
Tufts University School of Engineering, Team 1-6, Bell Fall 2023 crwdns2935289:0Tufts University School of Engineering, Team 1-6, Bell Fall 2023crwdne2935289:0
TUFTS-BELL-F23S1G6
According to an article on Reddit most of the buttons and the knob do nothing more that increase the time by 25%. Do you have anything more scientific that just a rudimentary test like the one on Reddit?
R Kilowatt - crwdns2934203:0crwdne2934203:0
have a Swan 2 slice toaster the cancel button come on as you push the down lever to start to toast and the cancel button comes on and the toast just comes back up tried pushing the button several times to see if its stuck but the button is not stuck cleaned it out upside down to get all crumbs out so its clean
Dennis - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 1,619
