Hair Dryer Fan/ Motor Assembly Replacement
  1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Fan/ Motor Assembly Replacement, Grating: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Fan/ Motor Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Fan/ Motor Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the screws on the handle and remove with a Phillips screwdriver.
  6. Hair Dryer Fan/ Motor Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully separate the plastic case with the Plastic Opening Tool.
  7. Hair Dryer Fan/ Motor Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the plastic case, locate the fan towards the back of the hair dryer.
  8. Hair Dryer Fan/ Motor Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
  9. Hair Dryer Fan/ Motor Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws holding the motor to the casing using a Phillips screwdriver.
    • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
  10. Hair Dryer Fan/ Motor Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Isolate the fan from the rest of the dryer.
    • Remove the screws holding the motor in place. Replace with the new component.
  11. Hair Dryer Fan/ Motor Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
    • Soldering Skills
Mitch
crwdns2935283:010/04/12crwdne2935283:0
37 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-29, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-29, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G29
crwdns2935297:011crwdne2935297:0
crwdns2936753:030crwdne2936753:0 129
crwdns2942667:0crwdne2942667:0 18,216
